[In Progress] Accidentally broke site with Bad CSS help!!!
    • September 3, 2024 at 7:54 am #21110
      J
      Jesse Vaughan
      Where does OSTA store it’s custom CSS from the themes page?
      (ie themes –> theme options –> Custom CSS Tab… )
      the change i made makes none of the tabs work so now i cant see that page..
      How can i find / edit the items there outside the helpdesk?? are they stored locally somewhere? in a database?? what can i do?
    • September 3, 2024 at 8:01 am #21115
      Hi Jesse,
      I understand that you can’t access the tabs to navigate back to the CSS page, so you can’t remove the CSS you added, which broke the tabs.
      But you can go to the page directly by adding /scp/theme.php#custom-css to the end of the URL of your installation.
    • September 3, 2024 at 8:02 am #21118
      J
      Jesse Vaughan
      yeah i tried that but it doesnt pull up the tab for some reason..
    • September 3, 2024 at 8:04 am #21121
      J
      Jesse Vaughan
      when I go there I only get the color theme page… even though the url is as you describe.
    • September 3, 2024 at 9:37 am #21162
      J
      Jesse Vaughan
      where is the actual data stored?
    • September 3, 2024 at 10:01 am #21165
      The data is stored in the database.
      But have you tried opening Developer Tools in your browser and manually looking for the CSS that is causing the tabs to disappear?
    • September 3, 2024 at 10:01 am #21166
    • September 3, 2024 at 1:33 pm #21173
      J
      Jesse Vaughan
      so maybe its’ not that but that’s the only thing I changed today.. old site works fine… but new site none of the menus work..
    • September 3, 2024 at 1:57 pm #21177
      Look for relevant error messages in the Developer Tools >  Console of your current web browser.
      Try accessing the page from a different web browser.
      Those are my best suggestions off the top of my head.
      Feel free to report back with any relevant information you discover.
    • September 16, 2024 at 10:57 am #21290
      Have you made any progress on this?
