[In Progress] Agent without permissions get’s a blank window
    • January 19, 2026 at 6:57 am #24421
      D
      Daniel Rosta
      Hello, we are running a configuration where agent’s aren’t allowed to change ticket priority value, they can still click on this in their dashboard and are prompted with a blank window, nothing renders and this kinda soft locks the agent from interacting with anything. I presume this is due to rendering method, is there a potential fix already for this or should I patch the renderer.
    • February 9, 2026 at 5:31 pm #24901
      Hi Daniel,
      Apologies for the slow response on this one.
      This sounds like it could be the quick-edit popup opening but having nothing to render because the agent’s role doesn’t have permission to change the value. I’d like to narrow it down so I can look into it properly.
      When you get a chance, any of the following would help (all optional, but the more the better):
      1. What version of osTicket Awesome are you running?
      2. What exactly is the agent clicking when the blank window appears? For example, are they clicking a priority value in the queue list, or clicking something inside the ticket view?
      3. Are there any errors in the browser console (F12 > Console tab) when the blank window appears?
      4. Does it happen in a different browser?
      5. A screenshot of the blank window would be very helpful if you can grab one.
      In the meantime, if you can confirm which element triggers it, I can take a look at whether the click target should be disabled for agents without that permission.
