[In Progress] Anpassungen im Layout To Parent Forum February 22, 2021 at 1:36 pm #7457 S ID-HO.NETParticipant Hallo, ich habe mir heute das geniale thema verdient. Leider habe ich ein paar kleine Probleme mit meinen eigenen und Vorlagen. Hierzu habe ich 2 kleine Fragen: Gibt es sich um die Möglichkeit, die zu ändern, um die Rechte zu verlieren, um das Logo zu erhalten? Gibt es die Möglichkeit die Schriftgröße der Menüs? Leider kommt die Größe da nicht so gut rüber. February 23, 2021 at 11:16 am #7464 S stevlandKeymaster Is there a possibility to change the one to lose the rights to get the logo? Sorry, I do not understand the question. Is it possible to change the font size of the menus? Unfortunately, the size doesn’t come across as well. Which menu? Staff Panel / Client Portal? Send a screenshot of what you want to change and I will try to help. February 25, 2021 at 1:29 am #7471 S ShimoParticipant @ID-HO.NET as native german speaker unfortunately i don’t understand your questions either ^^; Maybe it would be better to just post your question in your native language or you use a translater like http://www.deepl.com to translate it in english before You must be logged in to reply to this topic. Topic TagsAnpassungenheaderSchrift
