July 2, 2020 at 4:24 am #6022CEODCParticipant
I’m running osTicket Awesome v1.14.2 with PHP 7.2.31.
We have some two additional fields on our default tickets.
One type with type “Short Answer” and one with type “Choices”.After updating from v1.14.1, these fields are no longer editable.
The URL changes to https://support.***.eu/scp/tickets.php?id=917#tickets/917/field/50/edit however no prompt to edit the field is displayed.I’ve confirmed this doesn’t affect the same installation with v1.14.2 without osTicketAwesome.
Could you confirm this, or is there any further details I can provide to help resolve this?
July 10, 2020 at 6:40 pm #6048NNIcholasjansenParticipant
I have the same problem but it looks like they have not even looked into the issue for you?
It seems to be an issue with all custom fields
July 13, 2020 at 9:04 am #6053SstevlandKeymaster
Hi guys, sorry for the late reply.
This will be fixed in the next release.
For now, please open /include/staff/ticket-view.inc.php in a text editor and change line 1000 from
<a class="inline-edit" data-placement="bottom" data-toggle="tooltip" title="<?php echo __('Update'); ?>"to
<a class="ticket-action inline-edit" data-placement="bottom" data-toggle="tooltip" title="<?php echo __('Update'); ?>" -
January 21, 2021 at 10:43 am #7266MMario KischporskiParticipant
we still have the same issue on the newest available version “osTicket Awesome for osTicket 1.14.4 (Revision 1)”.
Why is this still not fixed?-
January 24, 2021 at 10:17 am #7291SstevlandKeymaster
Thank you for bringing this to my attention.
It appears that an upstream change of code in osTicket resulted in my fix being overwritten somewhere along the way.
It will be fixed again in the next releases. But if you want to manually fix it right away you’ll look for the following code in /include/staff/ticket-view.inc.php around line 1007:
<a class="inline-edit" data-placement="bottom" data-toggle="tooltip" title="<?php echo $title; ?>"
href="<?php echo $href; ?>">which you’ll change to:
<a class="ticket-action inline-edit" data-placement="bottom" data-toggle="tooltip" title="<?php echo $title; ?>"
href="<?php echo $href; ?>"> -
January 25, 2021 at 2:35 am #7293MMario KischporskiParticipant
thank you.
The fix works fine. -
February 5, 2021 at 1:55 am #7378MMario KischporskiParticipant
I upgraded from 1.14.4 to 1.15.1 (Revision 1) now and have the same problem again.
I again had to make the manual change in /include/staff/ticket-view.inc.php file.
February 5, 2021 at 8:13 am #7383SstevlandKeymaster
Yikes! I’m at a loss. Thanks for letting me know.
