[Resolved] Display issue
    • January 29, 2018 at 8:30 am #752
      m.may
      If I click on the Admin Panel and then click on Dashboard the screen renders incorrectly, I have the same results using IE,Edge &Chrome.
      All the fields overlap each other.
      Thanks
    • January 29, 2018 at 10:34 pm #769
      Hi @m.may,
      I am not sure what you mean by “overlapping”… everything appears to display perfectly in your screenshot.
      Just kidding! It’s a hot mess that I have been procrastinating on dealing with for a while. I will attempt to clean this up soon. Thank you for your diligence.
