April 22, 2020 at 1:12 am #5597Adie-ITlerParticipant
Hallo Forum!
Ich habe immer folgende Fehlermeldung in der Ticketübersicht:
“” ); $( “table.list.queue.tickets a.preview” ).wrap( ” <br />
” ); $( “td.osta_priority.osta_priority_low” ).closest( “tr” ).addClass( “priority-low”); $( “td.osta_priority.osta_priority_normal” ).closest( “tr” ).addClass( “priority-normal”); $( “td.osta_priority.osta_priority_high” ).closest( “tr” ).addClass( “priority-high”); $( “td.osta_priority.osta_priority_emergency” ).closest( “tr” ).addClass( “priority-emerency”); jQuery( “.truncate a” ).each(function(i, value) { var $link = jQuery(value); var text = $link.text(); if(text.length > 55) { $link.text(text.substring(0, 55) + “…”); } }); function myFunction(x) { if (x.matches) { // If media query matches $( “tbody tr” ).wrapInner( “” ); $( “.overdueTicket” ).closest( “tr” ).addClass( “overdue” ); $( “.overdue td.osta_ticket” ).append( ” <br />
” ); $( “.paperclip” ).closest( “tr” ).addClass( “paperclip-icon” ); $( “.paperclip-icon td.osta_ticket” ).append( ” <br />
” ); $( “tr” ).each(function() { var $test = $(this), $href = $test.find( “.pull-right”), $target = $test.find( “td.osta_ticket” ); $href.appendTo($target); }); $( “tr” ).each(function() { var $test = $(this), $href = $test.find( “.pull-right”), $target = $test.find( “td.osta_number” ); $href.appendTo($target); }); } else { $( “tbody tr > .wrapper” ).contents().unwrap(); $( “.overdueTicket” ).closest( “tr” ).removeClass( “overdue” ); $( “td.osta_ticket .overdue-ticket” ).remove(); $( “td.osta_ticket .pull-right” ).remove(); $( “.paperclip” ).closest( “tr” ).removeClass( “paperclip-icon” ); } } var x = window.matchMedia( “(max-width: 760px)” ) myFunction(x) // Call listener function at run time x.addListener(myFunction) // Attach listener function on state changes “Kanns ich da einer einen Reim drauf machen?
April 28, 2020 at 5:34 pm #5624SstevlandKeymaster
Hi die-ITler,
You are using the attachments_preview plugin (https://github.com/clonemeagain/attachment_preview).
There is a known incompatibility with that plugin.
You can either disable it or use the workaround that another user came up and shared in the forum.
Hallo die-ITler,
Bitte entschuldigen Sie die verspätete Antwort.
Sie verwenden das Plugin attachments_preview (https://github.com/clonemeagain/attachment_preview).
Es ist eine Inkompatibilität mit diesem Plugin bekannt.
Sie können es entweder deaktivieren oder die Problemumgehung verwenden, die ein anderer Benutzer im Forum aufgerufen und freigegeben hat.
