May 6, 2022 at 6:08 am #10225IozinfotechParticipant
osTicket Awesome version: 1.16.2
Hello. Words with italics aren’t inline with the rest of the text. The i directive in svg.css has the following set:
display: inline-block;
color: #128dbe !important;
top: 4px;If I remove those, then the text displays properly.
Before
CSS changes
After
May 24, 2022 at 6:01 pm #10489SstevlandKeymaster
Hmmm.
If you’re using the formatting toolbar to italicize the word, it will wrap it in <em> tags, which will work as expected.
Thus I guess you are manually adding HTML tags yourself. If that’s the case, you must be an old timer like me. But perhaps you didn’t know that the <i> tag was depreciated many years ago, much like the <b> tag was replaced by <strong>.
In vanilla osTicket the devs used <i> as some kind of a short-hand for icons, and in this case the properties that are getting picked up are actually meant for icons that use inline SVG images.
My fear is that, by modifying that CSS you will end up with icons appearing wonky elsewhere in osTicket Awesome. And you may not realize the connection.
If my guess is correct, and if you still really want to use <i> tags to italicize words while manually formatting your text with HTML, the real trick (rather than editing the CSS that is intended for icons) would be to target the ticket thread text specifically, like this:
.thread-body i {
display: initial !important;
width: initial !important;
color: inherit !important;
height: initial !important;
background: initial !important;
position: initial !important;
}I hope this helps.
May 24, 2022 at 6:30 pm #10491IozinfotechParticipant
In digging into it more, I found that the issue only occurs when an email comes in from Gmail with the italics to create the ticket. Somehow Gmail is doing that weird formatting. If I click the ticket to edit it and then just click the Save button, the formatting becomes normal again. I don’t have to change any tags or anything. So it’s somehow related to Gmail.
May 25, 2022 at 7:56 am #10518IozinfotechParticipant
And yeah, old timer here. I forget about the tags when I do it manually. Plus it’s an extra letter, why make me type more than necessary?
May 27, 2022 at 2:27 pm #10529SstevlandKeymaster
Thanks for the update. I will add that fix to the next release in order to accommodate tickets from Gmail.
