[Resolved] osTicket v.1.17.3 PDF Print -> Wrong Time on printdate
    • December 5, 2023 at 3:10 am #19103
      Marcel Kramer
      we have the Problem if you print the Ticket via PDF, the time under print date is wrong. The timezone on php-settings are correct. Only the print date is wrong… the correctly time were 09:57 also UTC+1
      Can you help?
    • December 5, 2023 at 6:23 am #19110
      This is definitely not an osTicket Awesome issue.
      I recommend you either research this as a vanilla osTicket query, or ask for advice in the osTicket forum.
      Good luck!
