April 1, 2020 at 2:45 pm #5559DdfeenstraParticipant
I use a Dutch translation and figured out that I had to add this in my user css file to get the theme colors in the prioritybox:
td.osta_priority.osta_priority_emergency {
background: url(../img/priority-pattern-overlay.png) #fc6872!important;
td.osta_priority_high {
background: url(../img/priority-pattern-overlay.png) #e5bc61!important;
td.osta_priority_normal {
background: url(../img/priority-pattern-overlay.png) #a5cb59!important;
td.osta_priority_low {
background: url(../img/priority-pattern-overlay.png) #5bb3f5!important;
}I now can use my own priority translations with the colors from you, but on the mobile screen the colors are grey now. How can i get the colors there too?
April 2, 2020 at 2:26 am #5562DdfeenstraParticipant
I fixed it by editing /include/staff/templates/queue-tickets.tmpl.php:
$( “td.osta_priority.osta_priority_laag” ).closest( “tr” ).addClass( “priority-laag”);
$( “td.osta_priority.osta_priority_normaal” ).closest( “tr” ).addClass( “priority-normaal”);
$( “td.osta_priority.osta_priority_hoog” ).closest( “tr” ).addClass( “priority-hoog”);
$( “td.osta_priority.osta_priority_noodgeval” ).closest( “tr” ).addClass( “priority-noodgeval”);My user-css.css is now:
td.osta_priority.osta_priority_noodgeval {
td.osta_priority_hoog {
td.osta_priority_normaal {
td.osta_priority_laag {
}It works now also on the mobile layout, but I was wondering if it is possible to make this editing in an other file just like the css in user-css.css file so that I dont have to edit the php file again after a update of Osticket Awesome. Or, a better solution should be to create a way to let Osticket translate the priority texts. Now I have the Dutch translations of the priotity, but they are also in Dutch when I have Osticket in Engelish. No problem for me, but if it is possible to use translations and not having to edit files should be better.
April 28, 2020 at 5:24 pm #5622SstevlandKeymaster
Hi @dfeenstra,
It took me a while to figure out what you are asking!
It sounds like you’ve figured out how to manually translate the names of the Priority Levels (Low / Normal / High / Emergency) into Dutch.
You then discovered that this broke osTicket Awesome’s functionality, which relies on having the exact syntax of the words in English.
I am glad that you figured out a solution on your own. Nice work!
And yes, you should be able to put your code into the /osta/user-scripts.js file, which is conveniently right beside /osta/user-styles.css.
user-scripts.js loads after all of the other jQuery and Javascript and anything included there should override any previous scripts.
