November 5, 2019 at 2:27 pm #5278SstevlandKeymaster
After all of these years I still feel like I’m just scratching the surface of osTicket’s capabilities.
I have never known about Quick Filters, until now.
Anyway, for my first attempt trying to add a Quick Filter, I added Department to the Open queue. Nothing happened. I checked my vanilla copy of osTicket, still nothing.
So I tried adding Priority Level as a Quick Filter in the My Tickets queue. Bingo! It shows up as a button with a drop down menu.
Therefore, I surmise that some Quick Filters work and others do not. And for those that do not appear, it is an osTicket quirk and not an osTicket Awesome issue.
November 6, 2019 at 6:47 am #5281
asuaetech
ParticipantAn update! After tinkering a bit we have found that adding Quick Filters to the default queues installed with OSTicket does not work reliably BUT if you create a new custom queue, the quick filters seem to show up there consistently. For example – we ended up creating a fresh “Open” queue, retiring the one installed with the system, and now quick filters work there like a champ.
Hope this is helpful for anyone else interested in having this function available.
November 8, 2019 at 7:59 am #5285SstevlandKeymaster
Good to know. Thanks for sharing your findings.
December 9, 2019 at 5:41 pm #5370MsistemascscParticipant
Vos crees que este problema je tengo puédale venir por los mismos que te paso con los filtros? https://osticketawesome.club/forums/topic/delay-en-acceso-a-base-de-datos/
gracias
